Do the primary and secondary conductors of a transformer need to be sized for continuous load? Example: for a 225kVA transformer feeding a 500 amp, 208Y/120 volt, 3 phase panel from a 480 volt three phase panel, the primary of the transformer is rated at 271 amps. Can this be fed from a 300 amp breaker or do you need to rate for continuous load? Thanks.
