RichB
- Tacoma, Wa
- Electrician/Electrical Inspector
Ok folks--having a "Senior Moment" here:?,--Reason for the question--We are being told we have to size our service feeders to the busswork(250A) instead of the OCPD(200A)because the math in the NEC (2011) says so, so I am trying to pin our Engineers down as to why the change after using 4/0 for years, as all the other agencies do--after all the looking the only real differance is how hard the contractor needs to work(Cost is >$1 per foot between 4/0 and 250kcmil)
When determing ampacity I can use the 90 degree colunm for my derates based on temp---In this area the local ambient temp is actully only 68 degrees F--so I get to use I believe 1.11 as the factor from the tables----now when sizing to the component I use the 75 Degree colunm--so here's my moment--do I also get to apply the derate factor there also--or am I limited to what is in the table--here's my my math so far;
310.15(B)(16)--4/0 USE-2 90^o colunm=290A
310.15(B)(2)--68^oF ambient @ 90^oC=multiplier of 1.18=342.2A
310.15(B)(16)--4/0 USE-2 at 75^oC ==230A(Do I also get to use table 310.15(B)(2) here also--if so then 230*1.25=287.5 and we can use 4/0 vice 250) But if we are limited strictly to the table then 4/0 is 20A short
Thanks folks!!!
Thanks folks!!!
