How to size the OCPD for Fire pump?
NEC code make me feel confuse.
For example. 208V 50HP fire pump. how do you size the utility side fuse and generator side breaker?
For utility side, should I use RLA or 6 times of FLA? Is there a maximum size of fuse i can use?
For generator side, is the breaker size between 125% to 250% of FLA?
Please explain the way how to size them. Thank you.
