See following excerpts...I HAVE A BUILDING 35X19 m , total connected loads : 650KVA , how can sizing the grounding grid conductor (around the building), VOLTAGE SYSTEM IS 380V, 3PHASE , 60HZ
PLEASE ADVICE
REGARDS
(4) Ground Ring. A ground ring encircling the building or structure, in direct contact with the earth, consisting of at least 6.0 m (20 ft) of bare copper conductor not smaller than 2 AWG.
(F) Ground Ring. The ground ring shall be buried at a depth below the earth’s surface of not less than 750 mm (30 in.).
(C) Connections to Ground Rings. Where the grounding electrode conductor is connected to a ground ring as permitted in 250.52(A)(4), that portion of the conductor that is the sole connection to the grounding electrode shall not be required to be larger than the conductor used for the ground ring.
That is correct!Thank you Smart
is that mean there is no calculation to obtain the ring conductor size?
PLEASE ADVICE
REGARDS
