8ft, steel rods 5/8 or larger and non ferrous 1/2 or larger.
mentioned in NEC 250.52
It also mentions that a large ground rod might be need in different scenarios. I'm not sure in what situation would you use 2 ground rods
or a larger one. I'm guessing when you're using a higher voltage, but I'm not sure how high the voltage or current has to be to
consider going over the minimum grounding requirements.
