Saturn_Europa
- Fishing Industry
- Electrician Limited License NC, QMED Electrician
I work at the Doctors Without Borders office in Freetown Sierra Leone. The office is served by a 3 phase, 230/400 volts. There is a 50 kva back up generator.
There are low voltage and medium voltage power lines directly in front of our office. the low voltage lines start from a pad mounted transformer about 400 meters away. There are many taps on the low voltage line, some are illegal and poorly done. We only have power about 50% of the time and often run on generator for days on end.
The medium voltage power lines come directly from a turkish "power ship" that is moored in freetown harbor. the medium voltage is very consistent and reliable.
We have asked the poco to supply us with our own medium voltage transformer. they are trying to sell us a 100 kva transformer for around $30,000. The 50 kva transformer is around half as much.
On the hottest day of the year the office pulls around 33 amps across the three legs for around 23 kva. No future growth is predicted. Peak loads do not exceed 30 kva.
I have zero experience with medium voltage transformers. What is the correct size for this transformer. Is there an engineering rule of thumb to quadruple the predicted size of the transformer?
All loads are single phase. Most of the load comes from mini-split air conditioners.
