ACDCBag420
- Rutlant Vermont
- Solar
Im installing a couple of schneider multi mode inverters that are going to have an inverter output circuit connected to a 125 amp breaker in the main distribution panel. This circuit is going to be run outside and will include two enclosures one for the ac system disconnect and the the other for the gross production meters. The inverters inputs are both 60 amps so the circuit will have a full load current of 120 amps. Would I be able to use a 125 amp meter socket for this instalation or would I need to apply the 125 percent rule and use a 150 amp socket? sizing the disconnect was much easier, manufacturers seem to only make 100 amp or 200 amp rated disconects.
