I'm looking for some clarification on a motor. A customer is having a problem with a vacuum pump. The pump is occasionally started without first relieving the vacuum in the chamber, so it's being started under load. This causes the breaker to trip. It is a 2hp motor supplied by a 1 pole 20 amp breaker, type BL, HACR. It is connected to a 20 amp twist-lock receptacle by a length of 14-3 SOW. The nameplate FLA is 18.4, so we've got a bit of a problem.
Using 24 amps FLA (Table 430.248) and multiplying by 125% (430.22A), I need conductors rated for 30 amps, but I can protect them with a 60 amp breaker (Table 430.52).
Here's what I'm unsure about:
I'm planning on replacing the 20 amp receptacle and attachment plug. When the wire size does not correspond with the breaker size do I size the devices according to the conductor size or breaker size? I think I need 30 amp devices. Likewise, I think I need to replace the 14-3 SOW with #10, but that seems like overkill. Do I size this cable according to the nameplate, Table 430.248, or the 30 amp attachment plug?
Can I use the 90 degree column in T310.16 and re-use the existing #12 THHN? (I think the answer to this one is "No")
Am I correct in using the "Inverse Time Breaker" column in T430.52 when considering the ITE type BL breaker?
I think I've got this mostly figured out, but I'd like someone to doublecheck me and set me straight if need be. Thanks.
