Low-impendence2017
- Tallahassee Florida
Im trying to make sure a breaker is sized correctly on an a/c unit. Nameplate says max 15 amp. Branch circuit ocpd is 15. Reason being is I think the inrush from the motor is causing the lights to dim. All feeder connections are tight. System is 240volt single phase. Would this be 1.25% x 15 = 18.75 ocpd next size up at 20 amp?
