rvirgo
New member
- Franklin, WI USA
I am trying to size a circuit breaker that has different current requirements based on the input voltage. The input can be 115VAC or 230VAC.The input feeds into a Frequency Converter that has a 400Hz output and a 60Hz output. The electronic rack we are building has 3 different configurations. If the input voltage is 115VAC then the input current for one of the configurations would be 12.6A. For the same configuration if I connect 230VAC to the input the current will be only 6.3A.
My question is: If I size the Circuit Breaker for 125% of the 12.6A. then when the customer connects up 230VAC the Circuit Breaker will at 250% of rating.
This doesn't seem right. Thus, I am leaning towards telling the customer of this problem.
Am I missing something?
Thanks,
Thanks,
