eddie_kerri
- cincinnati, ohio
I am assisting a friend in the state of Kentucky with powering his pole barn with a new 200 amp service. The URD cable will be direct burial from the utility pole at the road to the pole barn 450 feet from the pole. I have conflicting information regarding the size of the URD to allow for the long distance. I have been told anywhere from 4/0 to parallel 600 MCM Aluminum. The truth lies somewhere in the middle. Please advise as to what URD direct burial aluminum conductor size is appropriate for this application. Please note I am not looking for alternate methods to complete the project. If this was your home and you were required to install URD direct burial aluminum cable to power a 200 amp panel, what size would you use based on the NEC.
Thanks,
Eddie
Thanks,
Eddie
