Wattage rating of the solar modules is irrelevant. Most microinverters use AWG #12 wiring, which limits you to a 20A breaker per "string" (they are in parallel so they are really branches instead of strings) which in turn limits you to 16A total rated current per branch. You can have any number of micros per branch you want as long as the total current is 16A or less; there doesn't have to be the same number per branch, the modules do not have to all be in the same orientation, and shading a module does not affect the rest.Need help designing strings with micro inverters, 20a max for the breaker due to 120%. Is it just watts of the panels divided by 240? Not going over 16a for a 20 a circuit? Without using over the rated output of the micro as a guide for panel size?
Yeah, this olde skool. At least in PV land. A simple "string" is just a DC series circuit. So the CURRENT (Amps) is the same through every wire and every PV Module (aka Panel) in the string (or DC series circuit).Very helpful, what about string inverters? Is the concept the same as in sizing for ac output of the one inverter?
Not at all. String inverters are totally different and in addition to what Phil Timmons said there are rapid shutdown requirements that most likely need to be taken into account; microinverters are inherently rapid shutdown compliant.Very helpful, what about string inverters? Is the concept the same as in sizing for ac output of the one inverter?
String inverters are not all the same, inverters that use optimizers on each PV module (such as SolarEdge) are basically series strings of optimizers. String voltage and current is controlled by the inverter via communications to each optimizer (SolarEdge). Optimizers are basically variable DC/DC converters that isolate PV module voltage from string voltage. String current for calculating wire size is based on optimizer output current, not PV module current. There are minimum and maximum number of series optimizers and power limits per string. Always follow the manufacturer's requirements.Very helpful, what about string inverters? Is the concept the same as in sizing for ac output of the one inverter?
