I am running a 125 amp sub panel and I'm curious on where the code talks about sizing the grounded conductor. I will be using 2/0 aluminum for the hots. The panel will have mostly 240 volt loads so I'm not sure a minimum for the neutral. It will feed 240 volt circuits for a pool pump, hot tub, and a vehicle charger. The only 120 circuits will be a pool light and automatic pool cover. I know the hot tub will require a neutral too but just for the lights and controls I'm assuming.
Thanks
Thanks
