EdCampbell
- Mexico City
- Maintenance Technician
Hi,
By the way I am writing to you from Mexico.
I do not think they use the NEC code however I would like to keep this instalation in line with it as best I can.
I am new to this forum and quite new to the project I am about to undertake. I am in the process of designing a complete instalation for a factory with a floor area of about 4000m squared. Basically it will have the following equipment etc.
Main building lighting 34 x 1Kw metal halide lamps situated 8 meters above the floor.
3 levels of offices and storage areas illuminated by an assortment of strip lighting not forgeting the power outlets for standard office equipment and a few microwave ovens and a fridge in the canteen. (Total load of about 250 Amps)
At present one Variable speed compressor with a 75 Kw motor.
One production line which will also use about 80 Kw of power.
An Air conditioning system that will maintain the whole building.
Now I need to plan for future expansion as we paln to out in another production line (80kw) and a number of robots (?w). not forgetting a conveyer system.
The factory needs to run on a supply of 220 V and obviously 110 V ac.
What I would like to know is how do I determine the size of the transformer as the one supplying the building at present is only a 30 Kva. From my calculations I am looking at one of about 1000 to 1500 kva. but I may be wrong. I used the following formula :
volts x Amps x 1.73
3 phase Kva= --------------------
1000
Remember I need to plan for future expansion.
Thanks for your help.
Regards,
Ed.
volts x Amps x 1.73
1000
Regards,
Ed.
