Hi All,
I get error: Redundant Swing Bus Defined whenever I try to run my power system model. Details of are as follows:
Utility (200 MVA) connected to TF001 Primary. TF001 Secondary (22 kV) connected to BUS1000 (22 kV).
5 Generators (Each 6 MVA - 11 kV) connected to BUS0001 (11 kV). BUS001 connected to TF002 Primary & TF002 Secondary (22 kV) connected to BUS1000 (22 kV)
Downstream BUS1000, loads are connected.
When I perform load flow/ SC study, i get fatal error for 4 out of 5 generators : Redundant Swing Bus Defined
If I remove 4 generators and make use of single generator, I get no error
If only utility is used without any generators, no error
Can some please help me out. I have no idea where I went wrong.
