I do not have the latest code book. I?ll get one soon.
I need to know if a slash rated 120/240 2 pole breaker can be used in a 120/240 volt
service with a high leg as long as you don't put the breaker on the high leg?
In other words the high leg should be B phase could I drop down from the top of the
panel and insert a 120/240 rated breaker 2 pole and install in slots 5 and 7 and be legal? 5
would be C phase which would be 120 volts to ground and 7 would be A phase 120 volts
to ground or can I not use this breaker at all in this panel?
According to Mike Holts video on this art. 240-85A he say it can't be used on a high leg
system?
Here is a shortcut to the video very informative you'll enjoy it.
http://www.mikeholt.com/videodisplay.php?id=17
Ronald
[ May 02, 2003, 09:32 AM: Message edited by: ronaldrc ]
system?
Ronald
