Sleeves for low voltage cable through walls
Is there a requirement for sleeves to be installed in walls that are not fire rated/smoke rated?
Also, when using sleeves is there a ul listed method? Is emt conduit listed for the purpose as a sleeve with minis on each end to hold it in the wall?k Or maybe the question should be is the two mini's listed for the purpose of holding a sleeve in the wall.
Everyones bidding at cost and trying to make money by taking away old standards not neccessarily required.
