Can you use plumbing PVC in concrete walls and floors for sleeves to install EMT feeders
R Rahawi Member Location Nj Oct 19, 2012 #1 Can you use plumbing PVC in concrete walls and floors for sleeves to install EMT feeders
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor Oct 19, 2012 #2 Rahawi said: Can you use plumbing PVC in concrete walls and floors for sleeves to install EMT feeders Click to expand... As a sleeve I see no reason why you can't
R Rahawi Member Location Nj Oct 19, 2012 #3 Dennis Alwon said: As a sleeve I see no reason why you can't Click to expand... Thanks Dennise..I was thinking of the different fire ratings for this type of PVC as sleeve if it applies..!
tkb Senior Member Location MA Oct 19, 2012 #4 The NEC doesn't care, but the building codes may have something to say about fire ratings of sleeves through walls.
