M4gery
Let's say you want to put a receptacle or switch on the wall in a basement with block walls, you will be running romex thru the joists and around the sill plate, but when you run down the wall to the switchbox you want to sleeve the romex for protection.
In order to do this code compliantly, what should you do?
Run a PVC connector out of the box with a piece of PVC up the wall and have the romex come in the top without a connector and "from-to" setup? Or do you need said connector and from-to?
Or do you have to run the PVC down the wall and stop short of the box so that a romex connector can be used at the box?
