Slots on Cable Entry
We are using parallel single conductors as a single feeder supply to a given load. Is using a PVC Gland can avoid heating effects on metal sheets surrounding the cable other than a solution of using aluminum plate or providing a slot/slit in between cable entry?Can somebody provide another solution?
Re: Slots on Cable Entry
No.
You will have heating any time you have a complete circle of magnetic material around a single conductor.
