Open Neutral
- Inside the Beltway
- Engineer
Have a case where an outbuilding ('the shed") will be ~800 ft from the main building, and needs routine generic power, i.e. say two 15 or 20A circuits. We have to run 480v to a building ("the barn") 300 ft of that distance, to run a VFD. I suggested we could extend the 480 the rest of the way to the shed, to reduce the conductors and voltage drop; and put a small stepdown in the shed.
The electrician says if we have more than that sole VFD 480 load, we'll need a 480V panelboard in the barn, and that's $800. I assume that's because most 480 panels are 3-phase, etc. Is there a less expensive solution for two single-phase 480v circuits; one for the VFD, the other for the line to the shed?
(This is in California, so the electrons must be politically correct....)
