Electriman
- TX
Good morning everyone,
I am working on a project which I have small transformer (12.47kV/480V, 225 kVA) that feeds a 600A-480V switchgear. Utility feeds this transformer by 12.47 kV line.
I am wondering about the protection of this transformer. The client is concerned about the cost.
On the point of connection to utility, I have two options 1- fuse cut out 2- recloser if I use fuse cutout do I sacrifice anything?
For the transformer, can I use fuse cutout (or recloser) at the point of connection to utility for transfomer protection or do I need to use as seperate protection i.e SEL 751 for over current protection considering the secondary side of the transformer is 600A MCCB?
Do I need to watch for other protection i.e. ground fault protection.
If I need to use a seperate protection for transformer where do you put the CTs? I have seen it mostly primary side of the transformer and neutrual.
Please provide me your inputs.
Thank you in advance.
