this is my first post, i am mostly a residential electrician, but now getting into a little commercial stuff. my question is on a HS12F1.5AS Transformer. it has 277 volts feeding primary and load needs 120 volts from secondary. it is hooked up according to the information on the front of the transformer. the load is several acctuators for HVAC dampers. my question is, does the secondary need to be grounded? the tech support said it can be done either way. if it is not grounded, would it have an effect on these acctuators? several of them don't work anymore, and i am wondering why. these acctuators have a built in transformer to knock it down to 25 volts. thanks for your advice.
