We are considering the following installation:
A 20 A branch circuit from a lighting panel provides 120 VAC to a PLC control Panel. After passing through a 15A breaker and surge suppressor, the 120 VAC comes out of the panel via metal conduit, and feeds a GFCI outlet on a wall near the panel.
From this outlet, we feed a maintenance/bypass switch, which allows a load to be fed either from the utility power (wall outlet), or a UPS. The load side of the switch is then run back into the panel to supply UPS backed 120 V power to the PLC and associated I/O circuits.
The UPS is of the always online, double conversion type.
What special considerations should be given to grounding and safety of such a system?
Any obvious problems?
Is this a good approach to providing clean UPS power?
Thanks!
Thanks!
