I'm looking at installing a heater for a spa in a single family dwelling. The heater requires a 15 Amp GFCI protected circuit. No problem there. My question is whether or not I can use 14/2 Romex to install the circuit or if I have to bump to 12/2 to get a larger EGC.
Is there something in the instructions that require a #12 minimum EGC?
Not in the instructions, no. I'm a rookie at pools and spas, so I'm still developing judgment there. I look around in 680 and I see "not smaller than 12 AWG" in a bunch of places, and I wonder if I'm missing something about indoor installations.
Art. 680.43 tells us to wire an indoor hot tub per Parts I and II.
If we go to part II art. 680.21 (A)(1) It tells us a minumum of #12 for the EGC to any pool associated motor. I realize this is not a pool but the hot tub section says to follow Part II-- IMO you need #12
Is this a hot tub/spa, or a hydromassage tub?
I agree with Dennis, and want to add - insulated EGC.
If this is actually a hydromassage Tub, a #14 would be OK.
(I hear "hot tub" used as slang for what is actually a hydromassage tub around here, which is why I asked the OP)
680.43 is for outdoor installations, if I'm not mistaken. And 680.42(C) is for interior wiring to outdoor installations.
So it doesn't really cover this situation... but it is because of sections like that that I'm asking.
What NEC are you using?
The '08 on my lap right now has 680.43 Indoor Installations
I would consider this to be a hydromassage bathtub. See the definition in 680.2. So, 680.70 thru 680.74 would apply.I guess by 2008 definitions it would be either a "Self-Contained Spa or Hot Tub" or a "Self-Contained Therapeutic Tub or Hydrotherapeutic Tank"
It is a bathtub with a pump motor and a field installed heater.
Just going by what the OP stated, it's a bathtub, so it would be filled & emptied at each use.Does the water stay in the tub at all times or do you have to fill it each time you use it?
