Smallest MV Cable Size?
FaradayFF
Hi folks,
I need to run #10 Medium voltage cable from overhead line down to a padmount transformer. Can anyone recommend a vendor?
I'm imagining I should have a shielded MV cable for this.
Thanks,
EE
iceworm
Curmudgeon still using printed IEEE Color Books
The voltage sort of matters.
I've smallest seen are:
3C-#8 5kv
1C - #2, 15kv
Anything above 2.4kv will be shielded.
Most I have dealt with are Okonite. But I don't have a vendor I could recommend.
(edit to add) 310.10.E
Hv&Lv
Wow, #10... where you going to find it or a terminator for it?
what voltages do you have there?
Todd0x1
#6 5kv mv-105 is only $2something a foot maybe even if you only need #10 per your amperage you will likely end up using something larger
