stickboy1375
- Litchfield, CT
Also just a plain old t-stat did not work that well so we ended up adding a PID controller.
are you talking about vlux windows that close automatic when rain hits them?
There isn't any way to connect a connector of any kind? Whether there is a threaded hole or atleast a hole you can put a connector in. There has to be a way to protect the wires. That is per code and just common sense. Unless they are in romex or some other approved method.
Maybe post a close-up pic of where the wire come off, or out of, the window.
This is how they ship them, the carpenters just drill a hole in the framing and slip the conductors through for us like the first pics I posted.
Are you saying you just connect 120 v to the end of those wires?
A PID controller is a super fancy thermostat. As you can tell by my description I don't know exactly what it is either.Not sure what this means? The windows I have came with a driver, it gets a constant 120 volts, a switch leg, and a 2 wire load to the window... I'll take a picture of it when I go back...
As he mentioned, they are automatically-darkening panels for a bathroom. It's like a single large liquid-crystal pixel. The driver generates a suitable AC voltage to darken the window when the bathroom is occupied.
This is the relay that came with the smart glass, I'm not even sure why this is needed? Looks like a standard RIB relay to me....
Simple enough wiring diagram....
Here is the manufactures website...http://www.ltisg.com/ltiprivacy.php#
I would love to see how they wired the ones on the web site.
Hold on a second, I thought this was glass that heated, not turned black. :slaphead:Yeah, blinds are not practical for a window in a bathroom shower.so they went with these smart glass windows, they actually come normally fogged, its when you apply the voltage they become transparent.
Found this on the web site: http://www.ltisg.com/specs/SGULLC.0110.pdf Note the detail for the "LTI UL approved nipple".
I had looked at this product a while back for a job that didn't happen. I was really excited to try it.
