My project has several 120 V smoke damper actuators which are mounted to the damper's NFPA rated metal sleeve above the ceiling. The actuator is roughly 4" x 6" x 4" deep. Generally if this unit needs servicing,the whole actuator can be removed within the space 12" from the unit. The Engineer's comments state that there must be a 36" access in front of this unit per NEC similar to an air handler's service panel because the unit is 120V, but if it was 24 V this would not be required.
What would be your interpretation? Thanks
