are they just smoke detectors or combo units? they are likely interconnected as already stated. when were they made (look on bottom of sensor)? these detectors expire after a period of time. i had very bad luck with anything from USI Electric (lots made under the "Universal" brand name). what i had was multi devices, CO and smoke in one unit. only a few months old from manufacture date some starting acting funny for no reason what so ever. turned out to be a bad batch made. they were swapped out by builder for same units but they had newer manufacture dates. then after about a year or so they started acting funny again for no reason what so ever. i contacted USI and they wanted a $12 processing fee per unit to swap them out. that was BS so i purchased two new ones, tri function (CO, smoke, & natural gas). had them installed from about 1yr, manufacture date was 2013, and one tripped natural gas detected. turns out the device was faulty, and to boot, they are made not-resettable when gas is detected. i sent defective unit back to USI along with my letter to the affect of "... please stop making junk ...". they sent me a new unit with a 2014 manufacture date.
for all intensive purposes of discussion, when detectors became mandatory in dwellings and commercial and other, i think the detector boom was there and then the companies started down that path of "make cheap crap that works most of the time so we can make more $$" mentality.
with interconnected detectors its sometimes hard to find the one that is faulty. i am not sure if the Kidde units will show which unit actually tripped. if thats the case then maybe try to just run them from battery to see which one is the problem unit.
