mtnelectrical
- Essex, New Jersey
Is there any code requiring the location of S D in bedroom, 3 feet from doors (max distance)?
Check your local building codes and instructions with the smoke alarms your installing.
all right I will. But in your local building codes is there a distance for location of the S D?
I was taught the same way and I do remember seeing something in print about this distance but I dont remember where all I know is that it works.Is there any code requiring the location of S D in bedroom, 3 feet from doors (max distance)?
Check out this link.
16' of the pillow?
I put them up in the corner of the room so they sit against the ceiling and both walls at the same time. This way they last longer with all of the dead air space.
16' of the pillow?
I don't have time this morning - but if somebody follows the link to NFPA 72 on the FAQ link I posted, they can check out the section and see if I missed an item. Never heard of a "16 foot pillow" rule, IIRC.Yes...so you can actually hear the thing go off.
I have, for a smoke within 5' of a ceiling fan box. 24" for blades and 36" clearance.I have never failed an inspection because of smokes improperly located, but there could always be a first.
