GerryB
- woodbridge, ct. USA
There are 3 bedrooms. One is separated from the other two by the main room of a kitchen and dining or living room. The 2 bedrooms together on the other side have a common hall, smoke, smoke and CO2. The bedroom by itself has a smoke in the bedroom. From that smoke by the time you cross the main living area until you get to the common hall where the other bedrooms are is over twenty feet. The question is should another detector (CO2) be installed in the living room. I thought there was something in the building code or manufacturers guide about not more than 20 feet and outside each bedroom. Thanks
