jcbaka said:Does anyone know what is the code requirement for mounting spacing of smoke detectors under raised floor?
K8MHZ said:I am not sure what you are asking. Why would you put a smoke detector under the floor and not on the ceiling?
Please elaborate. The instruction sheet that comes with the detectors should tell you where to mount them with relationship to walls. For instance every one I have installed has instructions not to mount them too close to the wall if on the ceiling or too close to the ceiling if on the wall.
jcbaka said:The application is for a server room with 12" raised floor. NEC requires smoke detection under a raised floor and to meet code, is to install smoke detectors.
K8MHZ said:If you could point me to the particular section and paragraph of the NEC that requires the detectors I may be able to help you better.
Edit: Also which year NEC are you bound to comply with?
