mstrlucky74
- NJ
Have a smoke detector mounted in drop ceiling with slab above(guessing distance from ceiling to slab about 3'. They want smoke detector to be relocated to bottom of slab above. Two questions.
1. Limited drawings but trying to find out of ceiling is being removed and now its exposed. Could the smoke be concealed by ceiling?? Then you would need some sort of remote test switch or LED indicator in view, correct?
2. What do you think would be involved to do this relocate? There probably isn't enough cable to extend it to the new location. If there ceiling is remaining I guess you could put a box with a terminal strip right above ceiling where it was mounted and extend wire up to new location( no splicing allowed) or maybe you have to pull the wires back to a location then mount a terminal block or even pull back to the other devices and run new cable. It's a class A system. with return loop.
Thanks.
Thanks.
