Re: Smokes on/off AFCI??
Romeo
AFCIs are required in new work as far as the NEC is concerned. There are actually some guys who like the AFCI and are installing it elsewhere. The reason the NFPA has 'stuck to its guns' is documented in the ROP (Report on Proposals). It basically says the reason for AFCI protection is just that, protection. The Smoke detectors in new installations are supposed to be battery backup. They will still signal a fire if the circuit is opened by an AFCI. If the AFCI is removed from the smoke detector in the bedroom, then why even use AFCI protection on any other part of the bedroom? We all have heard the differences of opinion about the AFCI, but putting those opinions aside for a minute think about what I just wrote with an open mind. "A chain is only as strong as the weakest link".
There are some jurisdictions that have removed the AFCI from the smoke detector, there are some who have removed the requirement completely, there are some who have extended the requirement. What does all of this mean? It means that we will have a very good cross section of data to digest and help further the decision of whether or not to continue using the AFCI. Just my opinion.
Another thing I have learned about smoke detectors. It doesn't matter about education level or how wealthy a person is, the general feeling some people have is the smoke detector is a pain in the @#^%$&*((&^^$$### and they either disable them or want them in a corner (where in my opinion they are ineffective) or just say " I don't like the way they look in my new home"! Even architects have problems with locations of smokes.
AFCIs are only a small part of the problem with smoke detectors.
Oh yeah, AHJs and their changing the code to suit them. Most AHJs I have dealt with will work with you. They may have an 'opinion' of their own, but will work with you if you work with them.
Then there is the AHJ who is out to conquer the world. All I can say about that type is know your code, and know the process of going over his/her head if you think you are correct. I don't see this situation ever changing.
Pierre
