This is simply not an NEC application see 90.1 Scope. However the NEC does apply to the wiring methods used.Originally posted by mwelch:
This may not be a NEC issue;but is NEC MUTE on the issue? I did find it in NFPA 72. I was looking for the MOST RESTRICTIVE rule that would apply. THANKS ROGER for you input
