As the City's electrician I was recently called out to look at a situation with deadly potential. No one was hurt this time. It seems that one of our snowblowers shaved off a power pedestal on a boulevard with live 120/240 volts present inside. He was just widening the sidewalk due to the amount of snow we recently recieved. It was a plastic pedestal standing about 18"-20" above grade. I believe he actually pulled the conductors out of the conduits and had them wrapped around the auger. I was a day or two before I got the call ( I'm not sure why it took so long ). The local utility responded immediately and dealt with the issue. The pedestals are installed on the boulevards to feed street lighting. These pedestals are necessary for a disconnecting means for the street lighting circuits. Most of them are mounted in close proximity to the pad mount transformers offering them some protection by location. Others are mounted in the middle of nowhere. There are different styles of these being installed based on the developers design which is reviewed by the City prior to installation. Some are plastic, some are steel and some are weatherproof panels mounted on pressure treated wooden stubs. I don't believe any of these will be suitable to stand up to a snow blower. All seem to be low to the ground for appearance sakes. My concern is the winter months when they become invisible. I know when I suggest they have a minimum mounting height of 3' plus that I will get backlash because of the looks of them. However, safety must come first. It seems when they are installed in the summer months the snow was overlooked. Has anyone else dealt with this hazard or design. What other means of protection could be added to this installation. With spring just around the corner I will have time to research and deal with this but I am looking for some ideas.
