rswolff001
Let me ask this question again since I'm getting different answers from different electricians....
Wall mounted 65a receptacle. Portable machinery with fusing. There are several different pieces of equipment ranging from 30a to 60a each with its own SO cabling.
SO cord on the 60a machines is rated for 60a.
SO cord on the 30a machines is rated for 30a.
Can we plug any of the machines into the 60a receptacle (using the correct 60a plug)?
Can I put a plug rated for 60a on SO cable rated for 30a?
and again....all the machinery has its own circuit breakers and fusing.
On a previous post it was indicated I could not....though no one indicated why? Two electricians I spoke with believe it meets code.
No, I haven't pulled up the necessary parts of the NEC book (which I will) but often its not specifically clear.
Any further information is appreciated. And if you can point to the NEC part in question that will also earn at least my gratitude.
Thanks, Bob
Thanks, Bob
