GerryB
- woodbridge, ct. USA
I am going to attempt to drive a couple of ground rods Saturday here in CT. Thought I might drill a hole with the hilti and go from there. The ground is maybe frozen a foot? More?
As cold as everything has been, I'd guess it's frozen to your frost line. That must be around 36" in CT or something close to that.
Thanks for the replies, I'll let you know how I make out. I'm thinking that since I am driving them close to the house that maybe the house itself keeps the ground warm. Also I saw mulch on top of the ground where I'll be putting the rods. I'm not killing myself though
I hope you have the ground rod cup for the Hilti and yup that frost line will be at least 4' because we had the deep freeze before any snow. So because of the snow the top may be softer but there is really nothing for the rest of the ground to be warm, see if you can get a long drill bit that may help you pull it off..
i have two of those ground rod driver cups, in case i lose one.
they are my friends.
i've been driving a lot of strut in the ground to hold concrete forms
and sonotubes. makes a kick ass form stake, especially as the ground
where i'm driving them used to be a gravel terminal, and had 40' tall
piles of gravel sitting there for years. there's a 6" layer of compressed
soil that is harder than 2500 psi concrete. it'll take about 5 minutes to
get the strut thru that layer. on a positive note, the stakes don't pull out.
they don't come out at all... just cut them off flush when i'm done, and
drive them a couple inches further, and cover them up.
