76nemo
- Ogdensburg, NY
Had a e-call tonight. I had a new ceiling fan put in for a lady on Sunday. She call's tonight and says she has no power on a circuit which I knew to be on a different leg of the service. I get there and all is working fine. She explained what had happened. This went out, that went out, this worked fine, this went out,....so on and so on. The circuit she initially lost was the outlet for her oxygen. I got there and she couldn't apologize enough. "Everything is working fine now Brad, the problem is gone."
"No, it's not maam" What exactly occured? She explained in detail and then I knew she had a lost neutral somewhere. This was a mobile home service. I checked all the neutral connections at the panel, and all were tight. I unplugged her oxygen machine and performed a loop impedance test along with some adjacent circuits. As soon as I put a 15A load on the recep for the oxygen service, sh*t starts a dimming and flashing! Loop impedance showed 1.12 ohms for the neutral. I checked both legs at the panel and got zip. I checked the main disco and got 247. I went back inside and I had both legs. I cut all of the circuits besides the fridge, and minimal lighting. I go back outside and I found zip L-L. One lost leg. I go back inside and found 247 L-L. Switch on a few circuits and find the same leg lost. Back outside I go, with no additional loads, I found I had 247 line and load side of the main disco. I call the grid and they tell me because I had one leg to supply her oxygen, there wasn't an emergency. Okay maam, the main will also not cut loose, I DO have an emergency. Upon my initial call I had to go through 2 minutes of automated messaging to connect to an emergency line, when I find the extension's first prompt to ask for English or Spanish
. I have what may be an emergency here. Upon reaching an operator, she tells me it is NOT a REAL emergercy because it sounds like one leg is still constant so I can find a circuit where I could place her oxygen supply on! I told her,..."Maam, I have no main disco here, I DO have an emergency!!!!"
The grid comes and tells me to fully load all the circuits I can, and I hesitate. They respond that we are now a two man team and there is nothing to worry about, go ahead and load it up! The trailer was all 230V heat. They said to turn it all on including the oven and any other heavy loads. Not too pleased about this, I went ahead and did so. Upon doing this, they ran back in and yelled,..."Cut it now!!!"
Come to find out the main disco was bad, but would drop a leg depending on what was loaded. I had both legs line side and would drop one intermittenly depending. The main sizzled when I loaded it up with the resi's heat and stove.
Imagine having a serious fault and having to go through 5 steps of an automated machine to get tech support! They told me service was spread so thin, it may be 24 hours before the linemen would get there! Glad the place didn't burn down!
I am going to spend a lengthy amount of time with a letter for them. I am new to the line service here in NY, and to say the least, I am NOT very pleased!!!!!!
On top of that, it was an old MidWest main and it's no where to be found around here. A new panel will go in tomorrow.
Fr*ckin' fustrated
Fr*ckin' fustrated
