Looked at out door soda machine gfci outlet but no egc code compliant or not?
D domnic Senior Member Occupation Electrical Contractor May 4, 2015 #1 Looked at out door soda machine gfci outlet but no egc code compliant or not?
augie47 Moderator Staff member Location Tennessee Occupation State Electrical Inspector (Retired) May 4, 2015 #2 Lots of possibilities... when you say "no egc" does that take into account the proper conduit system can be the EGC without the use of an actual wire ? Is it possible the wiring is old the GFCI might be a replacement for an old two-wire outlet ?
D domnic Senior Member Occupation Electrical Contractor May 4, 2015 #3 soda machine soda machine Replacement for old two wire.
Dennis Alwon Moderator Staff member Location Chapel Hill, NC Occupation Retired Electrical Contractor May 4, 2015 #4 domnic said: Replacement for old two wire. Click to expand... Then a gfci replacement is compliant
