dick621
- Emmett, Idaho
what would make a sodium porch light come on at night then cycle off and on?Tryed tapeing the foto cell and it still cycles.
Make sure the correct bulb is installed.Many times a homeowner will put in a HPS where it should be MH,or vice versa,if that's not it,get a rebuild kit for the fixture.
Well how about a bad connection or fixture xtmr in wiring or a lamp not screwed in tight or the lamp is to close to the photo cell and its shutting it of then it turns back on and after some time its shutting it down change the angle of photo cell or distance from it to lamp .
Tape does not totally close the brite lite off sometimes .
Gas lamps need voltage to start and emit if its just a few volts off it will cut out or cycle .
Possibly mixed the line and load wires?
Nice edit, this wasn't there a minute ago
I challenge you to get light to pass through a layer if black tape.
Touching a HPS or MH bulb with bare hands will shorten its life? I know not to touch the halogens, but the others?
I actually meant swapped, not joined.I agree this is possible. So the photocell is bypassed and there is a bulb operating at end-of-life.
