Thanks Jraef
We are retrofitting and old conveyor that had an existing softstart long ago but for whatever reason the softstart was removed from the circuit and conveyor is now just started across the line. I looked at the softstart that is sitting there now and it does not have an internal bypass contactor but has a contactor in the same enclosure that is being used now for across the line starting. The literature for the softstarter says that an external bypass contactor is not required for the rating of the softstarter is sufficient to handle the full load running current of the motor once up to speed.
Sometimes a bypass contactor is used just because the soft starter needs to be in a sealed enclosure (i.e. NEMA 12 or 4). Soft starters reject about 4.5W of heat per running load amp, so for a 150HP 460V motor that's pulling 200A, that's a 900W heater in the box, it can get pretty hot inside.
We really dont need this softstarter for any electrical reaons (pretty strong power system with no voltage drop and plenty of current capacity) so I was wandering how beneficial this would be to put on a conveyor for mechanical reasons? Would there be alot less wear and tear on a conveyor extending its life a good amount?
Plenty of reasons to use them for mechanical issues, one mfr I used to work for used a marketing slogan that was "Electrical solutions for mechanical problems" because they were better justified for those reasons rather than strictly electrical. Belt conveyor's see extended belt life. I once had a belt salesman tall me they stopped promoting them for that very reason...
I figure with a conveyor we would use the torque controlled ramp?
Torque ramp is mainly useful when you must have a more predictable acceleration and don't care about current, because torque ramp usually precludes the ability to do current limit. In order to maintain a specific torque, it may be necessary to allow current to go where it will. But in your application, where you don't care about current because you could start across-the-line, then it might be a good choice.
If we install another conveyor in the proximity to the softstarter, (same size motor 150hp) and want to softstart it as well, is it typically cheaper to buy and additional softstarter or add additioanl bypass contactors to be able to start both conveyors in sequence off of the one softstarter.
No, it rarely works out cheaper unless the soft starter is exceptionally expensive, as in Medium Voltage. It takes more isolation contactors than people think it does at first glance.
Electrically is a softstarter to eliminate voltage drop at the motor itself, or on the bus the motor is being served from to eliminate issues with other motors. I would think that for voltage drop during starting at the motor itself, then cable size can be increased during installation as opposed to a softstart.
A soft starter INCREASES the "voltage drop" to the motor, that's how it works. the purpose, from that standpoint, is to reduce the VD on the supply.
Anybody have any good links for programming a softstart for a toruqe ramp based off the speed vs torque and speed vs current plots for a given motor.
I'm not sure anyone does it that way, but the current plot, as I said earlier, would be forgone anyway. The motor plots in general would be meaningless as well, they have nothing to do with what is connected to the motor; you would need the torque / speed curve plots of the load. You can sometimes get them from the machine supplier, but they too would be relatively meaningless in that they are based on across-the-line starting. All you really need to do it ensure that at any given moment, you always have more torque available from the motor than the
load needs to accelerate.
