marmathsen
- Seattle, Washington ...ish
- Electrical Contractor
What do you all use for drawing up electrical plans and site plans?
I often have used Google Drawings which is a very bare bones system but allows me to share my file with someone easily. I essentially just take a screen shot of the plans from the architect and then draw up my electrical portion overlayed on that image. It works fine for us internally but I prefer/need something on occasion that can export to PDF and generate a clean set of scaled drawings. Case in point I need to draw up a site plan for a new underground service including proposed equipment and conduit.
If you get a set of plans from an architect and want to draw up a lighting and electrical sheet, what software do you use? I believe that AutoCAD is pretty standard but geez it's expensive if I only need it a handful of times a year and I don't need 3D. I've used Inkscape (free open source vector focused) which is fine but I think software designed for the purpose would be more ideal.
Thanks All.
Thanks All.
