andykee
- United States
Hi folks,
Wondering if anyone has any knowledge of "Limiting reverse current" from solar module data sheets?
Scenario: Paralleling 2 strings of a 140w module(SF140-L) with 2.1 isc and a max series fuse rating of 4a. (2 x 2.1 x 1.25 = 5.25a) This would then mean that the each string would need to fused at 4amps and fused at 8a in the combiner panel. On the datasheet above the max series fuse rating it has listed the limiting reverse current at 7a. Does this imply that 7a is the actual the maximum current that the modules can actual take before it suffers damage? I have never seen this on a datasheet and was curious if anyone knew?
