andrew.tkelly
- Berkeley, CA
This is a bit of a structural/civil engineering question, but I figured I'd ask it here since it ultimately pertains to an electrical system.
Within a solar module's installation manual, it generally shows you a few ways to mount the module. Each mounting method is accompanied by a different mechanical load rating. I find that most traditional rail-mounting methods give the module a rating of 5400 Pa. However, if you move the rails to the extremities of the module, it reduces the mechanical load it can hold to about 1800 Pa.
My question is this: How can I know if the wind forces in my area are enough to surpass this 1800 Pa rating? I'm in the SF Bay Area, so I know that ASCE 7-10 standards require PV systems to withstand a 3-second gust of 110 mph (92 mph in the ASCE 7-16). I'm basically scratching my head, wondering, "Since I'm using this mounting method, will I need some kind of engineering stamp now?"
