Solar PV Micro Inverter Interconnection
happysanghvi
New member
Lowell, MA
We are doing one solar PV project where, we would like to have 68 enphase inverters.
The client has 240V, 3 Phase service. We would like to use M250 micro inverters, which is rated at 208V, 3 phase. How can we use these inverters if we want to use this for our project? Also, I would like to know how would we recombine more than 3 strings ?
Please write me back whenever you get a chance.
Thank You!:D
jaggedben
Northern California
With these inverters your options are limited...
Option 1: use a transformer to create a 208/120 wye to connect the solar to.
Option 2: IF it is a high-leg delta, connect 240V to the A-C phase and neutral. Do not use the high-leg.
You had best ask the utility which is the better option. If it's a high-leg delta and the high-leg is not rated for a high current then you are probably better off with option 2. See the recent thread on connecting to an open delta. If the service is designed for a relatively balanced 3-phase load, the transformer option might be what you have to do.
