lower right corner of each post is a "reply" button that replies with quoteDon't see how to quote, but on the above post by GeorgeB, using the DIN connectors is a great way to go, as can easily replace the solenoid.
Sorry guys I have to differ. DIN connectors for Solenoids are one of the stupidest creations in the known universe.
The are a mickey-mouse, ultra cheap, hard to terminate way, to put wire on a holding coil and they are not truly washdown rated, as far as I know. Only something like IP65 which is lame. I have bought some DIN connectors that allow for coming in with 1/2 flex conduit, but the weight of such is another knock on the overly fragile, major cheap plastic, DIN design. They simply refuse to make anything large enough or robust enough to work well in and industrial setting. What we have are things that are substandard on a good day. The units I have conduit on will have to be replaced with cable gland connectors in the future which is a downgrade. That is a bunch of exposed cable in the plant where liquid tight conduit would be 100x better. I went looking for a well made valve body in the sizes we use from 1/2 FPT to 2" FPT, and the only ones with decent electrical connectors are the big steam servos. They almost do not exist.
I don't know where you bought whatever you did, but good quality DIN M12 and M8 connectors are rated IP67 and IP69K (IP69K is submersible, akin to NEMA 6P). Brad Harrison connectors (now part of Molex) are the best I have seen. They have different versions, I like the Ultralock ones because they have a push-on cam locking system, but they make the regular screw-in type as well.StarCat said:Sorry guys I have to differ. DIN connectors for Solenoids are one of the stupidest creations in the known universe.
Jraef, those connectors shown are not the same pin configuration, but look possibly of interest if they can be gotten with the right one.
The conduit connector 1/2FPT DIN's are a joke, and cannot support the weight of the connected conduit. This causes all the stress to go on the male pins of the solenoid, unless you tie the conduit up somehow, so cable makes more sense.
This is what they look like, with the bottom pin not being used:
When I have spoken to sales guys at places like Parker, they choke on such requests.
The outfit I have been buying valve bodies from does not have this offering that I have seen, but I may have to dig deeper. This is mainly for 1/2-1" FPT for general plant duty solenoids.
I use solenoids with a female plug then buy the cable that matches, its a square plug, or can sometimes can order with long leads and use carfex to a j box.
Common sense tells you that such a device or other devices that can be installed or located inside the vicinity of a robotic-based machine-- can not have bulky raceways like metal conduits--that will interfere with its operation.
Having said that--flexibility is utmost importance.
And besides, if flexibility is not a great factor for functionality. . . why would you rely on the device to support the aforementioned metal raceway (conduit).
Most that I had worked on like food packaging and CNC machines use non-metallic flex raceways with flexible extension (cord) and with appropriate fittings at connection points to prevent water intrusion.
Machines that have hydraulic/pneumatic components.
Wash down is a common order of the day in food processing plants—usually at the end of a work shift.
