Solenoid Valve Actuator DC Supply
kingbambina
Saudi
Engineer
Hi,
We have an old actuator that is fed by 125 VDC. We received a new replacement for it but it is for 110VDC. Is it ok to use the same supply for the new one? I looked for the datasheet but it doesn't mention the voltage tolerance.
Thanks
motorized actuator or a solenoid type actuator?
Does it remain energized for long periods of time or is it intermittent in actual usage?
If intermittent you likely get away with more than if not within tolerable input range.
