I don't think you need one, but if you really want an additional electrode, I have used ground plates in a situation like this before. Our application had a number of large concrete monoliths poured directly onto bedrock, and with the entire area around them excavated we were having issues getting rods in. We went with ground plates under the concrete that was poured adjacent to the monoliths, that was used to level the surrounding area. A form 4" larger then the plate was built and thin layer of ground enhancing material was poured to provide a level surface. After the plate was placed a few more inches of GEM was added and then the final concrete went over that. You may be able to do something similar in the 4" of topsoil adjacent to the building and end up with an inch or so of soil so the concrete isn't exposed.
But I agree that it is probably not necessary with what you have already called for.
