fastline
- midwest usa
- Engineer
We have a safety device we are trying to design which will interrupt a motor load if we detect abnormal behavior. The issue is the space constraints as well as a wet location.
Just so people can understand the the issue, the breaker may be 200-300ft from the motor, and we need to 'automate' the interruption. This is NOT considered a disconnect, just need to get the motor offline until it can be manually disconnected and inspected.
The normal mode of the device is preferred to be N.C., but really the only reason for that is to not force the device to have to handle continuous across-the-line starts for no reason. However, we may not be able to avoid this as there would not be any power at the motor location until it is sent to start the load.
Motor size will range from .5-2hp primarily, all single phase applications.
If we could find a way to do this with solid state components, it would be great and I believe the standard for this is a triac with electronics to only allow for zero cross switching? I realize that won't eliminate the inrush hit however. I just don't see solid state used much in this way so I feel I might be missing something.
Or if there are any other thoughts on creating a motor interruption, I am open ears! I know this chat is probably a stretch.
